The top hinge of our shower door is pulling away from the wall, which causes the door to sag and leave a little gap when it's open. I tried pushing the hinge back into place and tightening the screws, but they simply can't be tightened anymore, and I don't want to strip them. What is the easiest way to fix this?
Whatever the screws go into is no longer holding.
So you need to find out what it is and then redo the support there.
If it is wood then I would drill a larger hole and glue a wood dowel in there and, once dry, drill pilot holes and resecure with the screws or even new screws.
If brick / masonry, t6hen perhaps gluing rawlplugs in may work or drilling and fitting larger diameter plugs may work.
Do you think I could get away with just using longer screws? I was hoping not to have to remove the door and to just replace one screw at a time. It is wood, and it only pulls away from the wall slightly, with that first picture showing the max amount it can go. Jan 26 at 12:40
Try putting some glue on a match stick and tap into the hole. A few hours later reinstall the screw, a longer one would help. Then repeat for the other screw. I am assuming these are fastened to a stud or some backing installed for this purpose. You might also check the lower hinges to be safe.
