The hinges for the door to my frameless shower keeps slipping and the door keeps rubbing:
Since I'm not the one that purchased/installed the shower, I can't be absolutely certain, but I'm pretty sure the hinges being used are the ones shown here.
The only solution I've found so far is to loosen the large screws on the hinge (shown in the images linked to above), physically lift the door so it isn't hitting the shower wall any more, and tighten the screws back down. But I've ended up doing this about every month now since moving into the house because no matter how tight I try to get the screws, the door keeps slipping. As a result, the screw heads are starting to get chewed up. Maybe I'm not tightening the screws sufficiently, but they're as tight as I can get them with a hand-held screw driver, and I'm afraid that if I over-tighten (by using a power drill) them I'll break the glass door.
Is there a better solution to keep the door aligned properly? Do I need to get different hinges? If so, can you recommend which ones I should get?
