I'm trying to tighten up a loose shower door handle. However, I'm having trouble removing the set screw and can't figure out what type of driver I need. I've tried flat head, philips and allen, but nothing seems to turn the fastener.
It's also an incredibly awkward place to get a good look at. What types of set screws are common for shower door handles
    I think you just need a hook wrench (there's no set screw)
    – Jasen
    Commented Nov 12, 2022 at 19:23
    I think that's a divot that you can hook to unscrew. Maybe try a hex key for leverage. Commented Nov 12, 2022 at 19:24
    Or plastic jawed pliers... Commented Nov 12, 2022 at 19:25
  • Was able to twist it with a hex key, thanks y'all!
    – James
    Commented Nov 13, 2022 at 4:23
Is there another hole on the other side? not required, but they are often in pairs. This looks like a spanner (or pin spanner or hook spanner) bolt, where that hole is just where the wrench hooks in to rotate the part; not an Allen wrench (or Robertson or Torx) setscrew at all. I don't see any sign of a setscrew from the image.
Pin or hook spanner image from canadianhobbymetalworkers.com
Given the use, that would make sense - a setscrew would probably corrode to uselessness in short order in that application.
