In order to raise -- and tighten -- a volleyball net every evening, we've attached a winch to one of the poles. The attachment is by two bolts going into the existing threaded holes in the pole.
It works, but the bolts aren't thick and, because the winch goes side-to-side a little, when the net is raised or taken down, I am afraid, they might snap eventually.
As you can see in the picture, the implement has two other holes -- plastic zip-ties are running through them now -- which could be used with some sort of U-bolt. Except a straight U-bolt will not work, because the pole's diameter is 3″, whereas the distance between holes is under 2″.
Hence my question about some sort of Ω-bolt (or Ʊ-bolt?) -- which would "hug" the 3-inch pole, but with the threaded ends going into the holes available? Do such things exist -- and, if so, what are they called?
Any other suggestions? I thought of using steel hose-clamps -- but they all tend to be wider, than our holes. And not as hard as a bolt would be, anyway -- just a little better than the plastic zip-ties...
winch attached to pole
  • Yes, though we call them U-bolts. U-bolt around the pole with the threaded ends going through the holes where the zip tie is, just what you described.
    – SteveSh
    Commented Oct 7, 2021 at 21:05
  • Yes, @SteveSh, that's what I wanted -- but the regular (straight) U-bolt will not fit, because the holes are closer apart, than the pole's diameter. The U-bolt needs to narrow -- like Ω... The U-bolts I've seen are all too hard to bend so much -- from 3" down to 1.5"...
    – Mikhail T.
    Commented Oct 7, 2021 at 21:07
  • Look up (Google) "antenna mast mount" for some ideas. (can't post pictures in a comment).
    – SteveSh
    Commented Oct 7, 2021 at 21:16
  • Mm, I don't see anything suitable -- could you post a link here?
    – Mikhail T.
    Commented Oct 7, 2021 at 21:22
    amazon.com/PRO-SIGNAL-33-12256-Antenna-Clamp/dp/B07NVJ1C67. I was thinking it might provide a flat surface for the cable winch to sit on. Don't use the bolts; just the serrated part.
    – SteveSh
    Commented Oct 7, 2021 at 21:30
I would use a conduit hanger.
It goes around the pole, tighten the nut and bolt that's on the left side in Pic. This will clamp the hanger onto the pipe.
On the right side, I added a small bolt, this is where you would secure the winch to the hanger/pole.
conduit hanger conduit hanger on pipe.
** Edit ** You could use a piece of kindorf with a kindorf strap...
Strap around pipe, kindorf other side of pipe and attach winch to kindorf. If you don't have small fingers, attach winch to kindorf first. For added strength from the strap sliding around the pole, you can screw through the strap into the pipe.
They have different types of kindorf, thick/thin, holes or slots.
Everything I mentioned can be found in a hardware store or big box store.
enter image description here enter image description here enter image description here
  • The only potential drawback I see to this is that the torque of using the winch could bend the stand-off portion of the bracket. Still got my +1.
    Commented Oct 8, 2021 at 14:51
  • Possible, let me grab a stronger hanger and add to my post.
    – Gunner
    Commented Oct 8, 2021 at 14:53
  • Ah, the new ones do seem stronger, than the zip-ties... But this also creates sharp edges on the other -- court- -- side of the pole, for a player to injure himself :(
    – Mikhail T.
    Commented Oct 8, 2021 at 15:11
  • Sharp edges are fixable with a file or grinder or even wrapped in rubber or pipe insulation after rounding edges.
    – Gunner
    Commented Oct 8, 2021 at 15:16
  • Not sure, if I can hook these through the existing holes in the winch, though... They are round -- made for bolts (or screws)... Ideally, it'd be something like this -- but with threads rather than "ears" at both ends... A curved U-bolt.
    – Mikhail T.
    Commented Oct 8, 2021 at 15:18
A U-bolt could pretty easily be bent to suit. Squeeze it together after it's on the pole, then wrap it with some wire. Now take a wrench, pliers, or bit of pipe and bend the legs back to parallel. An extra deep U-bolt might make this all easier, and you may need to trim the ends after shaping, for clearance.
This would also serve to stabilize it laterally, as the legs would grab the winch base at the outer ends of the mounting slot (they'll be pulled outward by the tension from the wider pole). Super simple and rock solid, especially if there's another slot at the bottom.
    If you use U bolts, use a spacing bar to keep the legs apart (as your winch has long holes that will not do that) and place nuts and washers on both sides of the winch so it won't butt against the pole and want to be bent around it by its mounting.
    – jay613
    Commented Oct 8, 2021 at 16:47
  • The legs of the bolt will naturally be drawn apart due to the spread caused by the pole. There's no need for a spacer. That winch housing is robust enough that deformation isn't a concern short of going absolutely ape on the nuts.
    Commented Oct 8, 2021 at 17:53
  • U-Bolt, +1. But bending it might be tough. Use a ~6" stick of 1/4" thick steel to make bracket 'ears', with four holes drilled into it. Two for the u-bolt and two to mount it to the pulley. Quantity two. (no washers or nuts necessary on the inside with 1/4" steel. If it starts to bend stop tightening.)
    – Mazura
    Commented Oct 8, 2021 at 19:29
  • That seems like a different answer, Mazura.
    Commented Oct 8, 2021 at 19:33
Strong and Firm
This is a pole bracket for a security camera. Buy the right size for your pole, so the gap between the ends of the wings is about half the pole diameter (or less). Search for "security camera pole bracket". They are not expensive.
pole bracket
Secure it to the pole with two or three metal hose clamps.
hose clamps
The resulting strength of the attachment to the pole is incredible, and the large face with versatile holes allows you to attach your crank very securely also.
Here I have two of them attached to a 4 inch pole in my garage. I'm using them with cleats not winches because I'm using block and tackle in my garage, and I'm only using one hose clamp because I don't have the kind of stresses that a winch would apply.
Two pole mounts mounted on a pole
I think this is more suitable than brackets that are mainly intended to keep pipes from falling off walls.
  • Thanks, I looked at these, but I don't think, they are strong enough for the sideways stresses of cranking -- by an enthusiastic volleyballer eager to start playing :)
    – Mikhail T.
    Commented Oct 8, 2021 at 16:38
  • These are much, much stronger than anything else that has been suggested here and 10,000,000 times stronger than your wire ties. Use two hose clamps, this spreads the load vertically. Rotationally around the pole, the edges of the mounting bite into the pole.
    – jay613
    Commented Oct 8, 2021 at 16:44
    We're not using wire ties. We're using bolts -- because the pole already had them (something else used to be attached to it years ago). Did you mean the plastic zip-ties pictured? Those aren't adding much, I agree...
    – Mikhail T.
    Commented Oct 8, 2021 at 16:58
