I am replacing an Intermatic mechanical T104 single circuit timer with a new Intermatic P1353ME unit that can control 3 individual equipment items in addition to the timer clock.
Each of the three circuits can control either 120v or 240v equipment items independent of the timer power source. Can this timer be used with existing 240V, 20 amp, 2 wire plus ground power feed from the panel?
I plan to use this 20 amp circuit to power three equipment items at 240v. Total load is below the 80% load for the 20 amp circuit.
With an existing 2 wire dedicated 240v circuit, what leg is considered "Line" and what leg is considered "Load"?
