The faucet runs even when the handles are turned off so I wanted to pull these off and see if I could figure out what is going on...
but I have no idea how to get the faucets off. No visible set screws.
The rings above the conical base pop up then the conical base turns about 2 full revolutions then stops. Is it possible these things are just press on?
EDIT: found the set screws, but it did just slide off. With the ring above the conical part moved, and the conical part screwed all the way down, a small set screw was revealed!
  • Have you checked for Allen/set screws? Feb 19, 2015 at 1:56
  • Yep, as I mention in the post, there are no visible set screws that I can see. Feb 19, 2015 at 3:09
  • Figured it out, see edit to original post. Feb 19, 2015 at 4:44
