My faucet is leaking from the base of the handle so I need to replace the cartridge or rubber seat. I'm having trouble removing the cap to the handle to change the cartridge and rubber seat.
I don't know what brand the faucet set is but it might be Delta since all the other faucet sets in the house are Delta.
As the photo shows, the handles are circular. The caps on top of the handles don't seem to come off by twisting counter-clockwise. I also looked around to see if there's a notch to stick a screwdriver into to pop it off. No notch either. I checked for a set screw too. No set screw on the handle.
Someone else suggested there might be some mineral deposits around the caps so I tapped the cap/faucet with a rubber mallet. It still doesn't come off.
As an example of why I thought we need to twist counter-clockwise, one of our shower handles have a similar handle type. I was able to twist the cap off with a counter-clockwise motion to expose the screw to remove the handle.
I tried to find installation instructions on Delta's website for their Monitor faucet set that looks like what I have but again, no luck. I'm running out of ideas on how to remove the cap without resorting to using an oscillating tool to cut the cap or faucet off.
Can anyone tell me what else to try to get the cap off the faucet handle? Thanks.
