We have one of those built in jet tubs in our master bathroom which I believe is on its own circuit breaker that has 20a on it.
We have a contractor that will soon be redoing our master bathroom replacing everything including this tub with a free standing tub.
What we currently have is something like this
At the opposite side of our bathroom wall I have something that looks like this:
Every so often when I do use the tub I have to reset it using this button. What I want to do is replace this tub with this:
This tub specifically says this:
“ Pump with durable motor. Innovative technology enables this pump to provide a strong and steady level of hydro-massage; Power Requirement: 110V, 60Hz, 15A dedicated circuit, GFCI outlet to plug into.”
Can I reuse the electrical work from my old tub for this new tub? If i go downstairs to my breakers I see this:
About fifth one down says “hydro tub” with what appears to say 20a on this switch. I am pretty confident this is specifically for our jacuzzi/hot tub. So does that mean the contractor can reuse most of this setup?
Just looking to see whether this os going to be a large expensive job or not so bad?
