We have a 1 3/4" bath situation in our house. Like many 1970's ranch style homes, the floorplan's master has only a single vanity, toilet, and shower. The guest bathroom, which is attached to one of the bedrooms, has a tub (likely because that's where the kids would be.)
The original floorplan design called for 3 bedrooms. Ours is actually two, where the "master" is actually smaller than the space that's opened up by removing the partitioning wall that made the 2nd, and 3rd bedrooms. So, in short, our master is not really a master, and the 2 bedrooms that are now one serve as the master for us. Consequently, it is where the full bath is and we don't need a bathtub in the master bath. To complicate things, that makes our master bathroom the guest bathroom when we entertain. Bleh.
Knowing all of that, we were considering swapping moving the tub to the "master" and the shower to where the bath is.
Hurdles
Drain Location:
For the current bathtub location, we can simply adapt by installing a linear drain with a curb-less shower. For the new location, the drain is off the walls by about 13", so we'll need to either re-plumb, or elevate the tub and run the pipes under.
Bigger Issue and Question:
Where the tub is going, we have studs on the faucet end, and block wall on the opposite end. The distance from the block wall to the stud is 61". We need to insulate the block wall with 1" foam and then add 3/4" furring strips for the drywall, and then 1/2" X 2 backer board or drywall.
So, that's 2 3/4" eaten up from the available rough opening, reducing the available finished space to 58 1/4".
Would it make sense to put a 54" tub in this space? If so, what would I do to frame out that anomaly and not have it look like garbage?
The wall will be tiled above the bath.
Model
Model 2
  • The original floor plan design and/or bedroom locations and layout and how they influenced you decisions is not really relevant to the question about the space needed for the tub. Rip studs to the appropriate size, after drywall or tile backer board, and attach to exciting studs to get your space to fit a 54" tub. The plumbing should be a separate question.
    – Alaska Man
    Apr 2, 2021 at 21:26
  • @AlaskaMan what are “exciting” studs? Or did auto-F-up get you? :)
    – Solar Mike
    Apr 2, 2021 at 21:35
  • @SolarMike i speak, therefor i exit. Err, I mean yeah. Its all to exciting.
    – Alaska Man
    Apr 2, 2021 at 21:40
    The master that is not a master is now our master was 2 bedrooms do you follow ? I gave up what is the problem? With the tub? Anything to do with a choice would be opinion, but I would want the plumbing on inside walls.
    Apr 2, 2021 at 21:48
First thing I'd do is challenge whether the wall finish stack-up you described is actually required.
Could furring strips or hat channel be embedded in the same plane as the XPS foam? If so there's no loss of dimension due to the furring strips. Are furring strips even needed? Could the subsequent layer of drywall or backer board be held by adhesive, or by screws through the foam into the block wall?
Why two layers of drywall or backer board? Would one layer suffice? What about a thinner alternative such as Schluter's KERDI membrane? (I've never used that product; it's just an example that caught my eye.)
Also: the water-shedding layer in the wall could (should?) go in front of the flange of the tub. When placed there you don't have to allow space for this layer in the rough-in sizing.
If you do go with the 54" tub and need to make up 4 inches somewhere you're going to have to just build a box. It can be completely invisible if you make the box the entire width of the room, ie make the whole room 54" wide. But maybe there's a way to avoid that and also make the space useful. For example, frame a built-in shower bench opposite from the faucet.
If the the 4" build-out box extends wider than the width of the tub by one or two stud bays then that 4" plus the 3.5" depth of the existing wall could be turned into a built-in storage space. It's kind of shallow, but.. it could easily fit rolls of toilet paper, feminine supplies, cleaning products.. a whole lot of rubber ducks (Youtube, James Veitch Is A Terrible Roommate)..or hide-away towel racks, maybe?
  • Two layers of backer board, one layer at each end. 1/2" x 2. I definitely could embed the furring strips at the same plane as the foam board...the foam board is solving the insulation problem on the west wall, which gets hammered by the sun in the summer time. I suppose there may be another way to insulate. Maybe even a thinner material just for the width of the tub. Apr 3, 2021 at 4:53
