I've had my LG VC4 for a couple of years already, and never had issues with its functioning. However, about a year or so ago we noticed the exit pipe in the wall got clogged, since the washer started leaking water all over the laundry. I did some "investigation" and... you already know it got clogged with lint because of the question title lol
This is the type of "filter" this model has; given the size of the holes, it's made to get small pieces of cloth or lines, coins, keys, stuff like that - it's definitely not a lint filter.
My lifetime experience was with top-load machines, which always(?) had some sort of lint filter at the top of the water line or on the center of the drum. So I'm quite shocked when I tried to contact LG multiple times, and they either didn't get it and suggested me to get (pay for) a support visit, or simply said "your LG washer is expected to leave lint through the hose, given it's a drain hose (!!!), it's not a defect it's a characteristic of it".
So, what gives? Could the house pipe be too narrow? It's enough for the drain hose to fit in... Or is it really expected to not have a lint filter at all with front-load washers?
I'm not exactly sure why this was preemptively closed; unfortunately I have nothing to add to the edit, except mention the rules which seem to apply fine to my question, specifically:
"We welcome these topics: [...]
- Identifying the source or cause of a problem within your home.
- Installation, maintenance, and repair of major appliances.
