I have a Challenger branded Eaton sub-panel that contains 8 Challenger breakers. Most of them are “Type A” tandem (duplex) breakers, while the larger circuits are “Type C”.
In the answer to this question it was stated that all Challenger “Type C” breakers should be replaced with Eaton “Type BR” breakers:
What modern 20 amp breaker is compatible with my Challenger panel?
My question is if the Challenger “Type A” breakers are safe to continue using or should I also replace all of them with equivalent Eaton “Type BRD” breakers?
