I have a Thomas & Betts panel with 40 slots and was going about trying map out the circuits when I noticed a few suspect breakers. The entire right side of the panel contains only T&B (type TB) breakers which I think are fine, but the left side has a mix (some T&B, but a few I suspect shouldn't be there).
I don't want to spend money for no reason but my instincts tell me at least some of these breakers should be replaced (for safety and/or code compliance?), which is why I'm posting here to see if I'm right and should fork out the ~$60 to replace them or maybe worrying for no reason and can keep my cash in my pocket.
Based on some other posts I've found here, I think I know what to replace them with. But, again, looking for feedback.
Here's what I'm thinking, and THANKS in advance! -Jwawa
P.S. I can post a picture of the entire breaker panel, but felt like I was pushing it already with too many pics.
TBB20(40-40)C Service Panel
  • Slot 3: GE 20A HACR Type RT-692 TYPE THQL
    • Currently: GE 20A HACR Type RT-692 TYPE THQL
    • Replace with: Eaton CL120 or CL220
  • Slots 4, 9, and 10: Eaton 20A HACR Type C120 Type BR120
    • Currently: Eaton 20A HACR Type C120 Type BR120
  • Slot 11: Challenger 20A HACR Type C120
    • Currently: Challenger 20A HACR Type C120
  • Slot 13-14: Cutler-Hammer BR230
    • Currently: Cutler-Hammer Type BR230
    • Replace with Eaton CL230 Common Trip
  • Slot 19-20: Unbranded 230
    • Currently: Unbranded "E-45310" GFCI 2-pole 2x30A. This was for a hot tub which we removed when we moved in 20+ years ago.
    • This circuit is currently not in use, so no need to find a replacement. Replace with Filler plates?
