I have a typical lock in an exterior door as shown. Note that this door also has a deadbolt, so this is perhaps not a critical fix, but I still would prefer this non-deadbolt to be working properly.
The strike plate (1) is misaligned with the bolt (2) so the bolt does not go into the opening in the strike plate (the strike plate is almost 1/16" too high).
I am wondering how to fix this to maintain the most strength/integrity of the lock. Would it be one of these, or something else...?
(a) file the opening in the metal strike plate enough so that the bolt fits? Here is a closeup of the strike plate -- I do not think it leaves enough room for such a maneuver...
(b) move the strike plate down on the frame. Opposite problem here -- it would need too small a movement for the new holes in the wood to be separate from the old holes. Or would it be OK to set the new screw holes at an angle...?
