I have a deadbolt lock for a smart lock I just bought. The first problem is I have a metal door and need a drive-in bolt attachment for the lock.
The second problem is the the hole I made in the door is too big for the 1" lock. Its 1-1/8 inches so the lock is too small, so even if I got a drive in bolt attachment, its slightly too small and will fall right in.
How can I install this thing on a metal door? I was thinking either a. there is a larger drive in bolt attachment option that is 1-1/8, or b. I cut a rectangle out and put the deadbolt in as-is and find a way to drill it in from inside the metal door. Thoughts?
th
to it. That would be "one eighth-th". :P
