I'm unable to get the bolt out of a door. For a couple days before it was sticky, and you could push in the bolt on the inside of the door frame to functionality "reset" it so that the lock would turn.
Unfortunately it's jammed inside of the door frame and I'm unable to get it out.
I've removed the lock coverings and am using a screwdriver to turn the inside mechanism but it doesn't seem to be catching anything and I don't feel any movement of the deadbolt itself. The only thing that is moving is the little tab above the cylinder.
