My AC is not working. It is a Trane AC (Model 2TTB0030A1000AA). In the process of diagnosis I tried replacing the capacitor, and that did not help. I tested the fan blades and they no longer spin easily. I purchased a new AC fan motor (the blades now spin effortlessly).
I have a problem trying to install it. There are 4 holes where the motor should mount to the top grill of the AC. The motor came with 4 fine-threaded bolts that presumably go into the holes. The bolts do not have thread cutting tips and those holes are not threaded! See attached photo.
Notice that the hole (where the sharpy mark is) is not threaded. The bolt in the image holds the housing together.
EDIT Below I added is the corresponding hole in the old motor (notice the whole is threaded). END EDIT
Question :
Did I get a defective fan motor, or am I expected to tap these holes?
