A few weeks ago the condenser motor on our Trane XB 10 heatpump was making a screeching sound. I banged it with my fist and the sound stopped but I think it is not long for this world. This unit is about 17 years old. The motor is a GE unit with the part number 5kcp39fg v442as
I have twice ordered the specific OEM motor only to be sent the wrong motor. I'm now searching out a generic replacement.
The motor on my heat pump mounts with self-tapping screws through the grill into the motor body. Almost all motors I have found with the same stats are mounted with bolts on the end of the motor that pass through the grill and are bolted to it. I discovered that those bolts can be reversed or trimmed so that they will not interfere. This motor is a "frame 48". Are the holes in the body of the pump for mounting with the self-tapping screws common to all such motors? Or is this a Trane specific mounting method and I need to find an OEM Motor?
If it comes to it I could simply drill holes in the grill and mount the motor using the bolts.
  • Are there ports to oil the motor?
    – JACK
    Sep 21, 2021 at 19:36
  • My understanding is that these motors do not have ports intended for oiling. There are some holes on it but I think they are intended for drainage should water condense in it. Sep 21, 2021 at 19:39
    A few pictures would help all concerned.
    – Gil
    Sep 22, 2021 at 1:17
If it's making noise, and is on the exterior of the AC unit, it is likely not the condenser motor itself, but a separate fan motor and/or its bearings making that noise, as shown in the circuit diagram.
This makes it much easier to fix, since a condenser compressor motor is part of a sealed system that requires specialized high-vacuum equipment to service.
First, try applying a little ordinary motor oil, e.g. 10W30, to the shaft at each end of the motor. Use a needle-type applicator or basting syringe to the shaft itself, to any bearings, and, if there are holes just above the shaft, a few drops in each. Avoid dripping oil on rubber vibration isolators and don't over-oil. Run the AC for a while to see if that fixes the squeak.
This may not be a long-term fix, but should give you time to obtain the equivalent fan motor, which can easily be substituted with one of similar size, power, speed and electrical requirements.
