Bought a condo where exhaust fans weren't working with the plan to just replace the motors (both fans are identical). Found this replacement motor for the current JA2C463N motors (https://www.homeessentialsdirect.com/pennbarry-60030-0-1-80hp-115v-1400rpm-1spd-motor-60030-0/), but figured I should be sure about how to remove the motor from an existing housing before actually buying the new motors. I realized then the mounting nuts connecting the motor to the housing are inaccessible while the fan itself is on (nuts a bit out of focus here, but you can see the problem).
This is how the fan itself is secured to the motor.
There is this small hole on the inner side as well; not sure how or if it comes into play.
Any thoughts?
Separate from this question, but also the new motors indicate same power/hp, but 1,400 rpm instead of original 1,200--any thoughts there?
