Anyone know where I can get a trim kit for this basic round ceiling light?
It has an outer edge/flange that seats against the ceiling and there is a plastic light cover inside the outer edge. It has a rubber gasket that fits against the opening of the light and it has the 2 spring loaded tension wires that get squeezed together to remove and replace the entire fixture.
The part of the wire clip that is bent around the plastic inner seal broke off and the rubber gasket is deteriorated. I dont need the fixture inside the ceiling where the bulb is. I just need the entire one piece outer covering - about 6 inches wide.
