I have this light fixture in my bathroom, and need to replace the bulb. But I can’t get the glass dome off.
There are no threads between the glass and the plastic mount/base. And no externally visible clips or screws. I can pull the whole dome down, off the plastic base, by about an inch or so. Feels like it is mounted with a spring mechanism inside, because it resists and when I let go, snaps back up.
Tried with a little extra force but it won’t budge further than an inch. And the base has an inner rim which means I can’t get a good peek into the inner works.
Tried jiggling, rotating and even pushing up. No luck so far.
Any idea how this is supposed to work?
