This past fall we had a new HVAC system put in along with new duct work and insulation. There were a lot of people in my attic, and over the course of the project, the collar that sits above my whole house fan was cracked in a few places.
Before the last guys left, I ran the fan and realized the fan was rubbing against the collar, making a horrific noise. They adjusted it and it was fine. Since that was the fall, we haven't actually had a chance to run it since. My attic will get upwards of 120 - 130 degrees in the summer, and I'm worried about how this collar will hold up in that heat.
I had the company over two days ago, and one of the guys put some duct tape (the shiny kind, not the standard gray) over the cracks to reinforce them. I told them it was fine for now but come summer, if things start moving around because of the heat and there's a problem, that I'll be expecting them to come back out and fix it. They complained about not being able to find that collar, about the unit being so old they couldn't replace it, etc. etc.
I'm wanting to know two things:
- How would you expect a fix like their's to hold up in the heat? Am I worrying about this too much?
- Are these types of collars able to replaced, contrary to their opinion?
There's hardly any clearance between the fan blades and this collar, so I'm worried that eventually the rubbing will start happening again, long after they've been paid. I'm trying to be reasonable and work with them, but I don't want to end up with a busted fan two years down the road.
Here's what it looks like now:
