Some house context: apx. 1300sq.ft. built in 1960, block basement foundation and stick frame, asphalt roof in a relatively rural setting with high winds in plant hardiness zone 6. We usually cool by opening screened windows & doors and running box fans in them once daytime temps cool off, then try to close the house up and keep the cool in during the day, running ceiling fans for circulation. We also have a heat pump as A/C when needed. Heating is with the heat pump, electric baseboards, and mainly with a wood stove insert.
Currently, the attic is (poorly) insulated on its floor to partition it from living space, and it has connectivity with an unconditioned garage (not used for cars) and its attic. There are soffit vents and a small gable vent.
We had an energy audit and want to reduce our electric use, both to save $ and make it easier to cover our needs with on-site generation we plan in the future. Attic insulation is a weak spot and seems to be priority. The auditor's proposal includes:
- Air sealing accessible attic using one-part foam insulation, caulk, and half-inch R board
- Rafter baffles for air flow on the roof deck (we have soffit vents)
- Pull up attic flooring and blow in apx. 12" of new fiberglass insulation to get the attic to an R-value around 50
- Pre-fab stair cover/thermal barrier over the pull-down steps
This mostly sounds good to me. What I'm unsure of is: will all this attic insulation preclude installing a whole-house fan (or attic fan? not sure which is right) to help with summer cooling? Is it better to install that kind of fan at the same time, or make room for it at least, before/during the insulating work?
In case it helps answer this question or spur other insights, here's photos of the attic.
Gable vent on outdoor end of attic
Soffit vents go around both sides of house, and this pic also shows the bathroom fan exhausting out a soffit vent
Other end of attic facing attached garage
View into garage attic showing chimney
I will confirm this company's "air sealing accessible attic" will include better separating the garage attic from the attic we're insulating above the living space.
