I tried holding on to the rod with a monkey wrench/vise grip but it still turns when I try to turn the nut.
    Soak it in a penetrant? Not WD-40, something like Aero Kroil, or a 50/50 mix of acetone and automatic transmission fluid.
    – Huesmann
    Commented Nov 10 at 17:09
  • "How" is dependant on whether you want to save what it attached to or not. If not, I would hold the round silver part on the top of the ceramic thing with large slip joint pliers, then use a 6 point box wrench on the nut. The rod is so rusted it is not likely to be salvageable.
    – RMDman
    Commented Nov 10 at 17:17
  • @RMDman unfortunately the rod can turn while the part above the ceramic is steady.
    – Simd
    Commented Nov 10 at 17:19
    Have you tried to let the rod continue to turn, to see if it unscrews from the silver part?
    – RMDman
    Commented Nov 10 at 17:22
  • @RMDman I have to a limited extent. I could try that for longer.
    – Simd
    Commented Nov 10 at 17:52
If the suggestions in comments don't work for you, or if you feel they risk damage, you can use a nut splitter. It will destroy the nut but it should leave the threaded rod undamaged.
e
e
Photo credit: amazon.com
