There is a white vinyl piece that is removeable from the door frame that has warped over time. I have searched trying to figure out what it is called so I can try to find a replacement. No luck with Sill or Threshold parts. And the Manufacturer Code I can't find any google results for either. Any pointers would be appreciated. (I promise to clean up when I get the new part)
The raised white threshold piece is 1.5" x 34".
Door threshold for sliding doors
Manufacturer Code: SW-1, Series: 1000 / SGD-C20 MST: 10080
  • Mfr Code: SW-1. Commented Sep 4 at 18:59
  • Series: 1000 / SGD-C20 MST: 10080 Commented Sep 4 at 19:00
    Who is the manufacturer? It is probably proprietary to them, and looks alot like a trim piece in the sill of my Pella sliders.
    – RMDman
    Commented Sep 4 at 20:30
  • I put the Manufacturer code from the sticker above in the comments. But the Google search engine doesn't return any useful information about 'SW-1'. It is a builder install from the late 1990s, so something cheap from that era. Commented Sep 5 at 17:50
  • Based on some Googling, that may be a Milgard door. Perhaps reach out to them.
    – Huesmann
    Commented Sep 6 at 15:19
AFAICT it's just a threshold "spacer" to make the step-over as flush as practical—instead of the flanges sticking up and being a hazard to bare feet and tripping. You should be able to remove it and perhaps use a heat gun to straighten it out (if you can't find a replacement).
  • I guess that makes sense. I'm surprised that I can't find such a part in google search. Commented Sep 5 at 17:49
