Can someone tell me the name of this fitting? I presume it is steel about 10mm x 25mm x 10mm with a threaded hole on the bottom.
Has holes all the way through on alternate faces.
  • Whats the fitting used for and where? Could you provide some context?
    – vini_i
    Commented Sep 7, 2017 at 12:41
  • Unfortunately not. All I know is I found it near brass fittings in a Leyland shop.
    – AndFisher
    Commented Sep 7, 2017 at 13:27
This is a fairly typical basin waste ...
See where those rods intersect, there's a clamping block there.
Some people call it a "Basin Waste Arm Pop Up Rod Link Connector Metal Linkage" - but that's a bit verbose.
