I have a chrome sink that is a little over 32" in length and 19 inches and width. My new sink I bought is 31.49" in length and 18.1 inches in width.
So it's a little smaller both ways. How do I add more onto my counter on either side, so I don't have to hire a professional? The depth under my cupboard below the sink fits perfect. So I'm only concerned about the width and length.
    Even though it is smaller, does it cover the old cut out? Or does it try to, or perhaps, succeeds in dropping through the cut out?
    – Jack
    Commented Jul 26 at 6:08
  • Can you return the sink and get one more appropriately sized? It’s much easier to cut a little than to fill in a hole. Commented Jul 26 at 12:00
    Need more info. What is the counter material? Is the old sink drop in, or undermount? Is the new sink drop in, or undermount?
    – Huesmann
    Commented Jul 26 at 12:24
Two options.
  1. fit a new counter top with the correct size hole
  2. glue strips on the edges of the hole to make it smaller I would add one single long strip across the back but would put 2 strips ie 1 on each side each taking half the gap to make up which may possibly not show. Make sure the sink has sufficient area to rest on though.
  • 3: install some sort of trim plate to bridge the existing hole, with cut-out for sink. 4. Return the unused sink and exchange for one that fits...
    – keshlam
    Commented Jul 26 at 22:44
