I'm sure this is an odd question, but here it goes. One of my kids is currently obsessed with plumbing, and wants the sink to drain slowly.
Our drains, as for as I know, are pretty typical, and have white plastic p-traps.
Is there anything that I can buy and connect to the drain, either before or after the p-trap, to intentionally make the sink drain slowly? Even better if there's a way "turn it off" without taking the part back off.
I know there are shut off values, but those all seem to be for intakes, not for drains. And those, as I understand it, use different sized pipes, and you can't typically mix and match parts between them.
And of course, normally it's a really bad idea to "close" or partly close your drain, since that is past where the overflow connects. But I would rather have a safe and reversible way to "clog" the drain, rather than finding out later that the drain was intentionally clogged by my son with whatever was on hand at the time.
