I have a common drain for three sinks the clogs 1-2x per year. All three sinks back up at the same time and slowly drain. Total distance between sinks is about 25ft. I suspect that the sinks share a common lateral drain pipe and a T comes off that (hidden in walls) to a visible diagonal drain (several bends) and then down. All interior piping. If I snake down a sink, it just goes across to the other sink.
I have cleared the clog by snaking up the diagonal drain pipe (~5ft from a removable coupling). But as stated in other posts, this is probably only creating a hole in the clog. The suspect T is not visibly accessible. The T is probably ~10ft from the closest sink. There's a roof vent somewhere along the lateral pipe.
I have tried running hot water down sinks on both sides of the drain, but that does not seem to help.
I don't want to damage the cast iron pipes or replace them at this time.
Any suggestions for clearing the bigger clog? Anything safe to pour down the sinks that would dissolve hair, scum, etc? I can poor from both sides with or without water in the pipes (~10ft to the T). It will sit there for a while and slowly drain.
best guess of drain configuration
  • pool chlorine will eat hair, but may promote rust.
    – Jasen
    Feb 9, 2019 at 8:01
    You could contact a plumber that has a snake with a camera to check the drains.
    – d.george
    Feb 9, 2019 at 10:14
  • Hello, and welcome to Home Improvement. Nice use of Excel for a diagram! What do you put down the sink? Feb 10, 2019 at 0:35
  • Just the typical bathroom sink stuff - water, toothpaste, mouthwash, soap & cleaning materials, unintentional hair, etc. I suspect hair and soap scum are major components of the clog.
    – excel
    Feb 10, 2019 at 6:35
  • Did you ever get this resolved? If so, please give a check-mark to the answer that helped you the most, or write up your own answer explaining what you did to get it fixed and give yourself a check mark. That will help others with this kind of problem know that this has a resolution and is a good place to look for their answer.
    Aug 3, 2020 at 11:54
Epilogue: I ended up replacing a one foot section of the drain pipe below the T with a clear piece of PVC pipe. I drilled a hole in the PVC pipe and covered it with a sliding rubber coupling. I can now run a snake up the drain pipe to the T area without removing the drain pipe. I also tried a water jet, but it was difficult to maneuver. I also periodically pour hot water and liquid soap down the sink drain to reduce potential blockages. Not ideal, but manageable.
Thanks for the suggestions!
  • Thanks for coming back with your follow-up. If you think one of the answers (including yours) answers your question, would you accept it by clicking the check mark? Aug 5, 2020 at 0:26
Heavy duty professional drain snakes have a variety of attachments available for clearing all kinds of clogs but those are more of a pro tool than DIY.
I would attach one of the inexpensive plastic barbed clog removers to a snake and very carefully run it up the diagonal to the tee.
Cobra Drain Cleaner
You'd want to be very careful to make a good secure attachment so you don't wind up with a remover lost in the drain pipe. I'd probably use bailing wire and electrical tape and at least a 6" overlap. (You'll see you'll want the ring end lashed to the snake - that way the barbs pull the debris back to you.)
With patience there's a good chance the barbed remover will hack up and retrieve the clog.
  • Can you snake down the vent?
    – Jeff Cates
    Feb 10, 2019 at 21:47
  • yes but it does not help. A plumber tried that. The snake just goes laterally past the drain pipe.
    – excel
    Feb 11, 2019 at 5:21
If there's a way to securely plug two of the three sinks, then you might find a toilet plunger in the third sink would help clear the clog. Or, you could use one of those expanding drain cleaner bladders.
  • I may try that. i can remove the sink traps and close two of them as well as the roof vent. One concern: I'm not sure if I can force enough water down the pipe to clear more than a hole in the clog. Once enough flow opens up, the pressure will drop and the water may just go around/through the clog, like it does when I snake from below. Also, if part of the clog is in the lateral pipe, forcing water through may send it to the other side vs. down the drain.
    – excel
    Feb 10, 2019 at 6:48
  • That's why I was hoping to find a 'pipe safe" solvent I could pour down both sides that might loosen/dissolve the clog.
    – excel
    Feb 10, 2019 at 6:58
  • See this answer for a possible solution. Feb 10, 2019 at 12:39
  • Sounds like a good longer term fix once the clog is opened.
    – excel
    Feb 10, 2019 at 18:03
