I've seen diagrams on reputable electrical journals showing two grounding rods driven 8' into the ground with approximately 8' distance between then, the two rods connected by a length of 6GA copper wire with a clamp on each rod; and then there's a separate length of 6GA copper wire running between the panel and the nearer of the two rods, to which the wire is attached with a third clamp.
From such diagrams I gather than the conductor between the panel and the near rod must be a single piece, not that there has to be a single length of copper wire running from the panel to the first rod and then over to the farther rod. Is that correct?
