I'm upgrading 100A service to 200A. The existing 6ga grounding conductors need to be replaced with 4ga. The existing 6ga armored cable was clamped to the grounding rods with these clamps (with the bottom flipped over...)
However, the spec sheet for these state they are only applicable for up to 6ga wire size. I'm not able to find a clamp for 4ga armored cable to a grounding rod.
but then the armored cable would be pointing straight vertical. I want the cable laid horizontal.
Should I just go to a local supply store and ask them? Or is there a specific thing I should look for? Should I just use the existing clamp even though it says it's rated for 6ga and hope the inspector lets it slide?
