I know this is a well-trodden question here, but, as per usual, there doesn't seem to be an exact example of the particular fixture that's been previously asked.
I'm trying to install a ceiling fan where only a light fixture used to be hung. I removed the light fixture to find this pancake box in the ceiling.
This building is 100 years old, though I don't know how old the fixture is.
I was able to remove the 1" nuts from the holes where the wiring is coming out. I was also able to remove the two screws holding the box into place. There are also two metal stubs coming out of the box still; I'm not sure if they are nails or rivets, but they are loose and would not prevent the box from coming down.
The problem is, I can't figure out how to get the box out of its current hole. It seems to fit perfectly into the plaster/drywall. I've sprayed some blaster (to get those nuts off) and also around the edge, and I have tapped with a flat-head screwdriver around to get rid of some excess plaster, but it's not looking like it will budge.
Any advice?
Edit based on comments:
- The light had a ground wire connected to one of the screws, though, admittedly, it was barely attached.
- I was not planning on changing the wiring. It's an apartment in a multifamily building, so I don't have access to the ceiling or walls.
- The fan does have a light. I was planning on controlling the fan/light with pull chains. The fan (Westinghouse Comet) has explicit two-wire connection instructions, but I may be out of my depth.
At this point I could put the old fixture back on and give up, call an electrician, or keep trying to pull out that pancake box and put on a stronger box for the fan.
