I did something slightly stupid when preparing to mount a new fixture to a very old unused ceiling pancake box in a 96-year old home: I unscrewed the bracket that attached the mounting nipple to the box, under the assumption that I would be able to either re-screw it back in, or attach alternate mounting hardware. Instead, it seems that there were nuts holding in those screws, which are no longer aligned with the screw holes, rendering them useless as attachment points. I see no other obvious way to attach any kind of hardware to the box.
Ripping out the box will mean doing some violence to an old plaster ceiling that I'm probably not up for in the near term. Wondering if I'm missing some other option?
(ps, I know it's controversial to attach fixtures to old two-wire circuits. If it helps, I plan on updating the circuit breakers to Arc Fault Interruptors, and only use LED lamps in this fixture.)
  • Have you considered wall anchors to replace the nuts? Dec 28, 2020 at 3:17
  • That's not a bad idea!
    – Chris S.
    Dec 28, 2020 at 16:32
4 Answers 4
How annoying! OK get a set of drills and start sticking drill bits up through those holes -- butt end first. We just need to know the hole size.
Now hit a "Drill and tap" table. Anytime you tap a thread into a hole, you drill the hole to the smaller size (tips of the threads). Go to the table under "Fine thread bolts" and find the fine-thread size whose drill size is slightly bigger than the holes you have. Buy the correct drill and tap, drill, and tap.
Now you have what you thought you had in the first place.
You need to use fine-thread because coarse-thread won't have enough purchase.
    Or self tapping sheet metal screws. It's not like it's going to be a ceiling fan....
    – Mazura
    Dec 29, 2020 at 4:23
The insulation on your wire appears in good shape, I would suggest an old work ceiling box. You can leave the old box up there if you want but most likely will need to trim some of the plaster for a new box to fit. Most of the new “old work” boxes will be plastic and will support a standard light fixture but not a chandelier or ceiling fan. This is what I use when the old box is damaged, as a best practice I will normally slide some heat shrink over the cloth for a little extra protection incase the rubber is brittle.
  • Hoping to avoid cutting into the ceiling, but that may indeed be the only realistic solution.
    – Chris S.
    Dec 28, 2020 at 17:39
Probe through the screw holes. Is there any obstruction within an inch directly above the box? There is one knockout left unused in that box. Can you push or pull it out? Doing so will give you room to get one finger on the top side of that box...
Retrieve the nuts from on top of the box or acquire new nuts. Insert thin wire (a conductor or pair from CAT5 cable, floral/craft wire, thermostat/bell/irrigation control wire, etc) up through a screw hole and pull the end back down through the knockout. You'll have a roughly U-shape wire path from screw-hole to knockout. Slide a nut onto the knockout-end of the wire and use the wire to guide the nut so that it sits on top of the screw hole. Insert a finger through the knockout and use it to hold the nut in place while removing the wire and starting the screw into the nut from below. Repeat for all four holes.
Next you've got to tighten the screws. This is most easily done with an impact driver. Use short intense bursts of motion: with each burst the screw will turn a little bit relative to the nut, tightening the connection just a little bit, before the nut accelerates to match the speed of the screw. Some back pressure against the nut can be a big help. Use a prying tool to put tension on the screw-nut assembly, pulling the nut against the top side of the box. This increases the friction between the nut and the box and allows each drive burst on the screw to accomplish more. You might even be able to find an amount of tension where manual tightening of the screw works.
Finally, install a knockout seal to cover the hole.
  • This is clever. So far I have not been able to pop out that last knockout, unfortunately.
    – Chris S.
    Dec 28, 2020 at 17:43
    Drill a hole in the knockout right at the edge, insert a screwdriver and pry it out. Dec 28, 2020 at 18:15
  • @ChristopherSchoen See comment from Platinum Goose. Could also try driving a screw through the middle of the knockout, then pull on the screw to pull the knockout toward you.
    – Greg Hill
    Dec 28, 2020 at 18:43
enter image description hereCan you replace the pancake fixture box with a steel one? Is it fastened to the ceiling joist with long wood screws? Turn the power off before doing this.
  • That's what I'm hoping to avoid. Messy job.
    – Chris S.
    Dec 28, 2020 at 2:41
