enter image description hereI bought a brass lamp holder fitting online, but can't figure out how to wire it up. I'd be so grateful for any help, it's for my late granddad's old lamp and I'd love to see it working again.
  • Please post a picture of the top side.
    – Martin
    Commented Jul 26, 2023 at 9:53
  • Just added, thanks Marti
    – Khris
    Commented Aug 4, 2023 at 22:04
  • State your location, tension (230v or 110v) and the colors of the wires
    – Martin
    Commented Aug 5, 2023 at 7:48
The hot (black) wire is connected to the screw on the bottom connected to the springy tab, and the neutral (white) wire is connected to the screw with the threaded metal. The ground (green) wire is connected to the metal chassis of the lamp itself. Older lamps probably don't have a screw for ground. You can make one with a tap or self tapping screw.
  • Thanks so much Andrew, that's great
    – Khris
    Commented Jul 26, 2023 at 10:46
    The OP is probably somewhere in Europe where the color code is different (the socket is marked for an E27 base, not E26). The color are hard to see in the photo but I doubt they are black white and green.
    – DoxyLover
    Commented Jul 26, 2023 at 10:50
  • @DoxyLover My eyes see black, brown, and a light yellow. I do not think old or new UK wire colours used black and brown together. They used one or the other with different colours.
    Commented Jul 26, 2023 at 11:32
  • Looks like brown, yellow, and blue or black to me.
    – Huesmann
    Commented Jul 26, 2023 at 12:01
  • This design confuses me slightly. Normally the wires do not connect inside the socket area, and I don't see contacts outside the ceramic. I presume one is supposed to dismount the socket itself from the ceramic by removing the two recessed screws and there will be contact points on its back; that would resemble the socket housings I'm used to...
    – keshlam
    Commented Jul 26, 2023 at 12:15
