I'm remodeling a 2nd floor bathroom and after ripping up 2 layers of old tile and 4 inches of concrete I finally found the joist. My question is really sistering on new joist to the old ones. I need to gain 4 inches to be level with the flooring of the rest of the house. My idea was to sister on new joist 3 inches higher then the original floor joist to get the height I need then do 2 layers of OSB (1/2 inch each) to get my last inch to get the total of 4 inches needed.
The sistered joist would not run the full length of the floor joist and would just run the length of the room which is roughly 5 feet. Is it ok for me to sister on new floor joist to the old joist with the new joist being 3 inches higher ? I would be using a 2 by 10 onto the old 2 by 10.
So instead of the new joist being flush with the bottom of the old joist I would be leaving a 3 inch gap at the bottom of the new joist to I can gain the 3 inches of height. I would just shim or using blocking to get the new joist to the correct height and level then use GRK rugged structural screws to screw the new joist to the old one.
I had one friend suggest just ripping a 2 by 4 to the correct length and height and then just laying that directly ontop of the joist and screwing that to the of the joist. I also think it's a good idea but since I have everything opened I figured I might as well sister on new joist seeing the this is a 114 year old house to start with so some new wood wouldn't hurt.
