We are currently renovating an empty house, under a gas fireplace we keep getting this mound of dirt, we have noticed a small hole in the wall under the fireplace which the dirt/mortar comes from. I've hoovered three times and it keeps coming back. What bugs would cause this?
How long does it take for the pile to re-appear? Is it sudden or slowly builds up over time? Does it only happen when you have used the fireplace?– ArmandCommented Nov 12, 2022 at 19:13
1perfect nesting place for mice, dry and warm– DIY75Commented Nov 12, 2022 at 19:14
It builds up over a week or so. The fireplace is a gas fire unused, the house has been empty for months– Rebecca MillenCommented Nov 12, 2022 at 20:39
Could mice get in/out that tiny hole? We have suspected mice in the property– Rebecca MillenCommented Nov 12, 2022 at 20:41
It's 2022. The 21st century, even.
Take an obsolete (or not) cell phone or video camera and set it up pointing at the hole, recording video at a low enough quality or frame rate that it can record 8-12 hours worth. Leave the light on so the camera can see. Review the video the next day to see what your cause is.
Odds are good that something is going in and out of that hole, though you might strike out if they are just pushing material out of the hole without exposing themselves.
The hole in the wall is possibly a cleanout for the fireplace. Look for some type of grating or cover inside the fireplace that leads to that hole. That could be buildup over time that's just falling out. There's usually a tray that fits in the hole. It's been cut square so it looks intentional. Try hoovering deep inside that hole.
1It's a gas "fireplace" and seems to be hanging above a wooden baseboard over carpet, so I doubt it has a cleanout, personally. There shouldn't be anyting to clean out, and the hole seems to be into the wall, not into the "fireplace" (or room heater?)– EcnerwalCommented Nov 12, 2022 at 19:30
@Ecnerwal It's a gas fireplace now, but maybe a regular one before. Many northerners burn wood in a gas fireplace.– JACKCommented Nov 12, 2022 at 19:41
It's a gas fire on the wall. The fire hasn't been used for many years and the house has been empty for 7 months Commented Nov 12, 2022 at 20:40
