Could you please help me determine how to properly replace this 4-wire cord that has pin style terminal with a 3-wire cord that has ring style terminals?
original range cord (left) replacement (right) terminal block on the range: terminal block on the range
old 3-wire cord from a previous range: old 3-wire cord from a previous range
Do I need to buy pin style crimps? or should I replace it with a a solid (as opposed to stranded) 3-wire range cord (not sure if it exists)
Outlet/house wiring is aluminum all 3 wires. Are there any concerns of mismatching aluminum/copper?
house wiring: house wiring
Range instruction MANUAL below mentions that the cord can be replaced.
If replacing the power cord, use only a suitable UL or CSA approved one.
  • Tighten the power cord using the power cord strain relief bracket supplied with the appliance.
  • Allow enough slack to easily attach the cord terminals to the terminal block
FROM THE INSTALLATION INSTRUCTIONS PER MANUFACTURER manual1
Proper grounding jumper cable was supplied by the manufacturer: enter image description here
or FROM THE INSTALLATION INSTRUCTIONS PER MANUFACTURER HARDWIRED: hardwired
NEW (left) cord vs OLD (right): Original cord (left) vs OLD cord from a previous range(right)
Additionally, what is the proper torque value for these flat head terminal blocks?
I think I found din-pin style connectors being used on original cable but I'm guessing will need a special crimp tool to properly attach and it will be really hard to buy just 2 of them https://www.airic-terminal.com/products_din_terminals_din_pin_terminals.html
But, on the other hand, would i be able to just use a ferrule and $20 crimper?
  • This post is hidden. It was deleted 2 days ago by JACK, ThreePhaseEel, BMitch♦. I think I found din-pin style connectors being used on original cable but I'm guessing will need a special crimp tool to properly attach and it will be really hard to buy just 2 of them airic-terminal.com/…
    – Matt
    May 2, 2022 at 16:53
Not an expert, but to answer my own question, from my research, it looks like I could just use a ferrule, heat shrink ssleeve and a crimper to make similar connection.
On the other hand, according to experts, this is a preferable solution to 4-wire range sockets and retrofitting 3-wire receptacles: Is it possible to add a retorfit ground wire to a (3-wire) Type SE, Style U cable from another branch?
