Don't use that. Use metal boxes. Specifically, you can get gangable metal boxes:
You can't tell from the picture, but they work. I have one in front of me right now - or rather, 2 of them connected. With one screw you can detach a side and then attach to another identical box. So for 2 gangs, you remove the left from one and the right from the other and then attach them to each other. For 3, 4, 5 you just repeat. Then you have all the benefits of a metal box - sturdy, fireproof, attach with screws where you want to, etc.
