Some motorized or mechanical devices can somewhat unintuitively be damaged by operating them in a situation where they have to do "less work" than normal. Some examples:
- Applying the accelerator in a motor vehicle where the tires aren't touching the ground can damage the vehicle (transmission?), because torque that is intended to move the vehicle is far too excessive when the tires have no resistance.
- "Dry firing" a spring-powered weapon such as an airsoft gun or foam-dart blaster with no ammunition loaded can damage the firing mechanism, which is designed to transfer the spring force into a projectile. The same applies to releasing a bowstring with no arrow nocked.
Modern devices may have mechanisms to avoid damage in these circumstances; for example, a modern car may disengage the drive train if it detects that a tire is spinning freely with no contact to the ground; power tools may include a belt to provide resistance when the tool is not in contact with anything.
For an upright floor vacuum, normal use of the vacuum would involve pushing it across the floor; regardless of the type of floor, there should be some air resistance from the floor. However, if we lift the vacuum while it is operating (for example, to carry it over an obstacle or across the room) there will be much less air resistance while the vacuum isn't in contact with the floor. Will this damage the vacuum over time?
