I am not a diy person but I'm trying to replace a light switch.
I bought a non contact voltage tester and a new single pole switch.
When I took the plate off and pulled the switch out it appears the ground wire ( if I know what I'm looking at is going from one switch into the other. After looking at some YouTube videos I'm a bit confused with the setup. The switch I'm trying to replace is on the left side it operates only the light in my master bedroom The switch next to it is a three-way switch that operates a hall light.
Before I start to replace the switch is this setup correct?
I have a ceiling fan light that doesn't work with the remote or the switch I'm not even sure if a faulty switch would cause that issue but I thought I would start there. Using my non-contact voltage tester the switch is getting power. I've turned the power off at the breaker and I'm ready to replace the switch but I was a little bit confused when I saw the way it was wired is this normal?
Attached photos.
