I want to test the switch and light socket for an outside light which stopped working. The switch and light socket (bayonet style) are similar to the ones in the photos below.
What's the best way to test them? I assume I would need to test the switch for continuity and then measure voltage across the light socket?
I have a non-contact voltage tester so would it be better (and safer) to use that instead for the light socket?
I also have a question regarding the voltage tester which has high and low sensitivity settings: before turning off power at the switchboard, with the voltage tester set to high, I get a voltage warning as expected. After turning off the power, the voltage tester is not activated but if I actually touch the tip of the voltage tester to one of the switch terminals I get a warning. The same thing happens when the voltage tester is set to low sensitivity mode and I make contact with one of the terminals.
