I'd like to build a 10x10 studio shed in the back corner of my lot. I won't have access to two of the walls as they will be inches from structures on the neighbor's lot. I can add exterior siding to the wall, before I raise it - but what can I do about the corner where these two walls join?
My only guess right now is to buy pvc corner trim, add construction adhesive, and then install the corner trim by moving it vertically down from the roof.
The end goal is to have everything watertight. If there is a different way to do this without corner trim, please advise.
    One reason some places have setbacks - obviously not your local area. So both of you will have unmaintainable areas trapped between the buildings - in which case you want to make sure the walls never need maintenance. I think that leans towards masonry built in place... – Ecnerwal May 17 at 20:40
  • Would I add trim may be a better question. – Ed Beal May 17 at 20:43
  • @EdBeal, I haven't built a shed before. I'm assuming I need to do this for rain protection. – dabi May 17 at 20:44
  • Hard to say not knowing anything about the siding you're installing. Corner trim means many things. – isherwood May 17 at 20:56
  • Since these two walls aren't visible/accessible, I was thinking something low maintenance like t1-11 or vinyl. Maybe cedar for the visible sides - decisions on this are flexible – dabi May 18 at 0:42
I would build the shed on rollers or skids three feet from the neighbors' walls. Finish it completely and properly, then roll or slide it into position, lever it up and slip the timbers out. A 10x10 shed should be very manageable.
Leave any unnecessary interior work for afterwards to keep weight down.
    I did this and it worked great. Used 2-1/2" pipes and it rolled into place real easy. – MTA May 17 at 21:02
  • The great think about a shed on skids is that it's a temporary building, so you do not need as much approval. – Jasen May 18 at 11:18
Use vinyl siding, build the two walls, stand the one with corner trim in place then stand and slide the other "mating" to the corner trim; end product looks like this (if you elect to pass on wrb). Sheath with zip wall, or with standard OSB and wrb to the face if you so please, install siding with corner trim choosing one side or the other for the trim to go on, build the other wall through siding with sheathing running by as it should (if you use OSB the material practically can't bow, so I don't consider the lack of face nailing a concern with any warrant). Hold your nailing back from the edge a good six inches on the siding on the wall without the corner.
If you don't want to pay for sheathing/wrb on a shed, skip them.
Now you have both walls built and sided (the wall with the corner trim will be laying on dunnage). Apply butyl type sealant on the leg that will mate with the other wall (butyl sealant doesn't cure, so it won't cure on you in the summer heat before you get a chance to get the mating wall in place). Stand the wall with the corner. Stand the wall without the corner, levering the siding into the joint to mate it with the corner trim, swing it back to your snap line, and bobs your uncle.
Now, a word to the wise: you will be in deep shit if that thing catches your neighbors house on fire or in any way contributes to damage of your neighbors property. If you live in a city in the U.S.A. there is no chance you don't have a setback ordinance. That could be real messy in court because they probably have their structure's proximity to property line 'grandfathered in' and typically you would not, even with 'non-permanent' structures (essentially no poured footing). If a fire happens and they don't know who started it, you'll have a hell of a time crawling out from the hole of "sir, your neighbors house has stood without damage for decades, then you built a shed and damage occurred" civil court and insurance companies have a low burden of proof, "probably your fault" is frequently good enough for "your at fault".
Likewise, if your neighbor ever gets annoyed with you, they can just call the building department to come rattle your cage. If your shed is too large to move or sits on a 'permanent' foundation, you could be forced to tear it down and likely be fined.
But people do it all the time with no issues. Moral: follow your jurisdiction's zoning, permitting, and code requirements if you live next to someone who hates you/everyone/everything or might possibly sell to someone who could turn out to have a problem with you/it/anything-and-everything.
-2
You need something more rigid than a typical trim at the corner, to allow for completion of the walls from the interior, such as a vertical steel angle cast in the foundation. Then attach the studs using through-bolts, and build the entire walls from inside.
  • I really don't understand what you're suggesting here. The question is about siding, not wall anchoring. – isherwood May 17 at 21:01
  • @r13 can you clarify what you’re saying here? This answer appears to have no relation to the question. – Tim May 18 at 9:23
  • @Tim What the OP asks? What does my sketch address? Erect the angle, attach the corner studs, then erect the walls, all done from inside. – r13 May 18 at 12:07
  • @r13 right, you’re saying use steel angle as both the corner trim + as a structural element which would hold the walls up, so it can be built from the outside in. – Tim May 18 at 12:10
  • @Tim So does my answer relates to the question or not? I am puzzled. – r13 May 18 at 12:15
