I am replacing some corner trim boards on my 1970s-construction house in Maine that have rotted a bit at the bottom. My house has cedar shingle siding.
Main question: what should I do as far as wrapping or weather-proofing before putting replacement corner trim back up? Also, after trim goes back up, do I caulk/seal between trim and shingles, or do I leave it unsealed as it was?
I have removed corner trim in one location to see what's underneath. Photos below.
- There is some tar paper (I think that's what it is) under the shingles but it is open at the corner.
- One one side, the cedar shingles appear to be installed atop some sort of foil housewrap
- On the other side, there is no housewrap - shingles are just atop the tar paper
- The corner trim pieces were just adjacent to the shingles - no sealant/caulking in between.
- Where housewrap exists, it was kind of folded around the shingles and was between the shingles and trim.
One main concern is that water can get between the corner trim and the cedar shingles and could work its way behind the shingles...although it doesn't appear that this has happened, as I don't see signs of water damage underneath.
In addition to the question of what should be done here, I'd be curious to know how bad/lazy it would be to just do nothing for weatherproofing and slap up replacement trim boards (given that I don't see signs of water damage underneath)?
Thank you for your thoughts.
Image of corner: note housewrap under shingles on left side but not on right
close-up of housewrap, which extends less than an inch beyond shingles in a few places
this was position of housewrap between shingles and corner trim: foil side faced the edge of shingles, and backside faced the trim
