My main door has a vertical reinforcement bar that locks into the ground and above the door. Unfortunately, it does not share the same key as the main door lock on the left.
I would like to replace both cylinders in order to use the same key for both, and ideally use a more secure key mechanism.
How should I proceed to replace the cylinder on the barlock? I do not see any way to open it or remove it. The brand is Esety but it seems it was acquired by Mul-T-Lock in 2007, and their original website does not exist anymore (I could only find an archive of their old catalogue, which mentions vertical bars, but I don't find mine). I am located in Belgium, if that matters.
Esety bar
Close-up of the barlock cylinder, its brand is Iseo:
Barlock cylinder close-up Barlock cylinder face-on (I damaged the paintig a bit more when trying to remove the cover between the two pictures)
I was able to pry the cover of the bar itself at the top and the bottom of the door, but not at the level of the lock. Instead, it is the lock that is coming out of the door (which actually seems like a flaw since you can push it from the outside!). See these side views of the top and the lock:
Barlock top – pried cover Barlock pried lock (note that the door is glossy, hence the reflection)
I can remove the cylinder of the door's main lock without problem, it is 6cm long and symmetrical:
Main lock cylinder
Both keys have the same profile, so I could re-key the main lock, but I would like also to use more secure locks if possible.
10
  • I would think that a locksmith could easily tell you if they can be keyed the same and what would be required.
    – HoneyDo
    Commented Dec 21, 2020 at 22:33
  • I take it both keys are standard pin-tumbler keys (with the jagged edge that interfaces to the pins in the lock) with no funny features on them (such as dimples or such), no? Also, can you post close-ups of both locks? Commented Dec 22, 2020 at 3:05
  • @ThreePhaseEel Yes, the keys are the old classic ones – I think it's called euro-profile? This is also a reason to change them to something more secure. I added a close-up picture of the barlock's cylinder (Iseo branded), and of the main lock's cylinder, which I can remove without issue.
    – Didier L
    Commented Dec 22, 2020 at 14:05
  • If you just want them to be keyed the same, see if the barlock cylinder key will slide into the main keyway. Doesn't have to turn, but if it fits, take the barlock key and the main cylinder to a locksmith, and they can change the pins so you can use the same key on both. Wouldn't be more secure though. To remove the barlock cylinder, have you looked underneath the cover around the lock cylinder? Maybe there's a small set screw, or a small indent where you can pry with a screwdriver. If not, you may need to remove the entire bar lock assembly to access. Commented Dec 22, 2020 at 14:51
  • @DidierL can you get us face-on shots of both locks please? Commented Dec 22, 2020 at 23:41
