In the photo below The red arrow represents the direction of the exhaust, as you can see there is a load bearing joist in the middle which I can't cut. I'm planning to build a recessed ceiling on that spot, so I can bend the exhaust in a 'U', going down and then up again, using 4 elbows.
I have had somebody say it wasn't a good idea because the grease will accumulate there, and be a fire hazard. What are your opinions on this? I'm kind of running out of ideas here and this feels better that cutting any kind of hole in that joist.
