I currently have a PCV water line to my fridge.
I’d like to connect a braided line to it to connect to the fridge. Is there a connector that will do this? I’m trying not to replace the entire line to my basement.
Sign up to join this communityI currently have a PCV water line to my fridge.
Assuming you're in the US that line should be 1/4". For the braided line you want 1/4" compression x 1/4" compression. It will have a fitting at each end with a rubber washer built in and it will connect directly to the fitting on the fridge. The other end of that line in the photo will have the same fitting.
Google "1/4" icemaker braided line"
