I need to know what type of connector, adapter or tubing I need to connect the fridge to the water line with this type of valve: white plastic with a blue shut off valve:
Blue shutoff valve
(Source: https://www.amazon.co.uk/gp/aw/d/B00PFTFV8W?pc_redir=T1)
  • Why do you want a shutoff valve to your fridge's water/ice maker? May 20, 2016 at 12:04
  • relevant? May 20, 2016 at 12:09
  • @DanielGriscom so you can replace/repair/move the fridge without turning off the main water shutoff.
    – Tester101
    May 20, 2016 at 12:30
You'll want something like this Pex 25-Foot Ice Maker Connector, which uses 1/4" compression fittings at each end.
Except you won't use the compression nut, instead you'll just push the end of the tube into the push connector on the valve.
  • When I purchased the connection as shown I came to find out the push connector is 3/8" and the fridge is 1/4". Is there an adapter?
    – user54166
    May 23, 2016 at 4:07
  • Probably. You should be able to find something at the local plumbing supply, hardware, or big box store.
    – Tester101
    May 23, 2016 at 10:06
