I have a shower that has a leak in the drain trap. From this picture, it appears to be leaking from the drain to pipe connection to the shower pan, but that part is actually fixed as it was leaking too. It is actually leaking now from the connection between the pipe and the drain trap turn in the center of this picture:
Is there a good epoxy or cement I can put around the connection to seal it? It is a slow leak. If not, what is the best way to fix it?
