I recently replaced my bathroom faucet including the water supply lines and I now have a slow leak from the drain pipe/P-trap connection. I'm thinking I must have accidentally bumped the P-trap or drain pipe when I was under the sink replacing the faucet. The leak is coming from between a 1 1/2" to 1 1/4" reducer and black ABS 1 1/2" pipe (see photos).
Question 1): To repair, do I simply need to replace the 1 1/2" to 1 1/4" ABS to P-trap reducer? If so, will this product work?
Question 2): As I've never cemented ABS pipe before, my understanding is that I use ABS cement to weld the two pieces of pipe together. If so, will this product work?
Thank you very much!
