I removed the pivot rod nut but the pivot will not come out like is shown on many videos. The pivot rod appears to be attached to the sink stopper, I can feel tension on the sink stopper when trying to remove the rod, any ideas?.enter image description here
    Can you turn it counterclockwise? I've seen a few that screw into the stopper but those are usually on all brass fixtures, not PVC.
    – JACK
    Commented Jan 11, 2020 at 17:17
  • Take a wider picture please, showing the whole rod.
    – tahwos
    Commented Jan 11, 2020 at 21:15
It may have a chunk of hair on it wiggle up and down while pulling out. Be prepared to pull the trap as everything stuck on this shaft will possibly slip down 1 wife , 3 girls , 6 granddaughters and all but one has very long hair , I have to clean drains in my current house all the time I liked my 3 bath house better I did not have to do it so often.
  • Thank you for the advice. The rod was not screwed into the stopper but in tuning the rod counterclockwise as suggested it broke up debris that then allowed the rod to come out. Our young kids must have put stuff down the drain, as Ed suggested. Thank you all! Commented Jan 12, 2020 at 18:35
Yes. Tons of hair stuck is usually the problem! I started by using a plastic “hair snake” to remove hair and gunk. I then twisted and turned the stopper both ways. Tapped on the ball of the rod with a hammer. Finally after much effort, I yanked out the stopper and rod saw that the rod had corroded and that’s what prevented me from removing the stopper. Will be inexpensive and a breeze to put in a new stopper and pop up rod. enter image description here
