I cannot get the pivot rod out to remove my bathroom sink stopper assembly. I unscrewed the nut easily enough. The ball part doesn't seem stuck but the rod will not come out. Every post/youtube video/instruction makes it seem like it will easily slide out once the nut is removed. I sprayed it with WD40 and will try again in a bit, but any ideas otherwise?
update: the WD40 worked! Now if I could get the dumb J trap loose!
    Glad you got it fixed. Please take the tour to learn how this site works. (Answers don't go in your question, and you need to accept an answer to resolve the question.)
    Oct 28, 2019 at 17:17
I have had the ball /pivot plugged up with hair and toothpaste more than once. I usually use a pair of pliers and a little force to remove it, in one case I had to remove the drain and use a long handled screwdriver to pry it out from the inside, once it was clean it slid back in place no problem. So give it a bit of force and it will come out.
